owel
I racked some Sony mic preamp and EQ, and the output I'm getting is about 13Vpp. I tried a Sowter output trafo (bought here at Prodigy pro!) and used it as 1:1.5 and I was able to bump it up to 17Vpp.
The problem is the Sowter 8751 output trafo won't fit inside my 1u case. Too tall!
Can you guys recommend an output transformer model that will fit inside a 1u case, with 1:1.5 step up?
