kambo
Re: NewYorkDave Mila Dual Tube Preamp Help Thread
« Reply #360 on: June 27, 2019, 02:14:30 AM »
maybe google
DC blocking caps on phantom power schematics
« Reply #361 on: June 27, 2019, 02:49:54 AM »
... readings between pin 2 and 1 on the input XLR are 44.6V. Same between pin 3 and pin 1. Any ideas? Is it too low?
44.6 Volts with a connected condenser microphone or without?
« Last Edit: June 27, 2019, 02:56:45 AM by rock soderstrom »
bernatvm
« Reply #362 on: June 27, 2019, 03:13:01 AM »
That's without a microphone pluged
bernatvm
« Reply #363 on: June 27, 2019, 03:15:28 AM »
maybe google
I understand you don't need DC blocking caps if there's an input transformer in the circuit...
« Reply #364 on: June 27, 2019, 03:37:12 AM »
Measure it with a microphone pluged in. It is very possible that your Phantom Power will sag under load. How do you realize Phantom Power? Schematic?
bernatvm
« Reply #365 on: June 27, 2019, 04:05:24 AM »
With microphone pluged i get 1.8V, which i can see is a very bad reading  :o I'm using Bo-hansen phantom psu, attached. Also I have a resistor between the + on the psu and the two 6k810 to reduce voltage, because it was 52 V without mic plugged in.
« Reply #366 on: June 27, 2019, 04:17:55 AM »
1.8 volts is not enough for most condenser mics  ;)
Remove the additional resistor, 52 V unloaded is ok. Check again your voltage under load.  Thats important...
« Last Edit: June 27, 2019, 04:29:24 AM by rock soderstrom »
bernatvm
« Reply #367 on: June 27, 2019, 12:38:03 PM »
Removed resistor and now I mesure 38.4V and working!! Now I have to play with it a bit. What should I expect with the range knob, should de flavor of the tubes be more present in higher positions?
« Reply #368 on: June 27, 2019, 01:22:36 PM »
38,4V is still on the low side, some mics will not work with that. AFAIK, the Phantom Power standart is 48V +/- 4V.
Your PP circuit is pretty basic, there are better ones, with regulation and load independent 48V.
The MILA circuit sounds pretty clean, in my opinion the less negative feedback (=higher gain setting) the more tube "sound".  You can experiment wird other tubes as well.  There is version with 6CG7 (noval 6SN7) tubes...
bernatvm
« Reply #369 on: June 27, 2019, 07:03:43 PM »
Can you recommend me a better phantom psu circuit?
bernatvm
« Reply #371 on: June 03, 2020, 06:28:33 AM »
Hi everyone! I was experiencing some crackle with my MILA. I realized it could be a bad tube so I changed it and it's gone! Do you know where can I buy good tubes for this? 12AV7 from ebay are not always good...
Also, I'm experiencing some hum on the maximum range position. When I touch the 1st tube in the circuit I can listen the noise of my fingers touching it in the output, I think this is called microphonic tube, so maybe no crackles but still bad tube?..
Last post October 04, 2013, 11:39:54 PM
by ding
Last post January 01, 2010, 11:40:23 AM
by Freddy G
Last post January 25, 2010, 04:43:13 PM
by rascalseven
Last post February 17, 2010, 06:35:39 PM
by dustbro
