More ratios on the SSL
Yann de Kéroullas
Active member
Hello there ,
I would like to ad more ratio to my gssl ( 6/1 8/1 , 15/ 1) .
Is somebody can explain me how I can calculate a ratio to make me possible to add those ones ?
thanks a lot
Y
empiricaly , yes why not ..
I owned a fucurite blue 330 and the ratio were coresponding exactly to the gain reduction it was aplying to the output .
Of course I can put some pots and after changing them for resistors ....
But it schould be possible to calculate them. I think ...
Yann
Although it's possibly great to have tons of ratio settings I'd personally recommended building GSSL as it is without any mods (maybe external PSU being an exception). Then you'll see if you REALLY need all those additional ratio settings.
If you do, it would be relatively easy to mod the circuit, although you'll probably need to wire ratio switch and additional resistors off-board.
Good luck!
