Silvas
74 ma per stage...2 stages per mic preamp
it should be about 40ma for each gain stage right??
Output transistors heat up a lot! but i have some really big heatsinks on them so there's not much heat.
Using everything as in the original hamptone schematics, but added bias trimmer for the prototype and idss control. I'm using the fairchild 2n5457 fets. The 1/2W 100R resistor were getting too hot, changed it for a 1W. My modules are built in my own designed pcb's and biased at exactly 12v. I should use a SOT resistor for biasing instead of the trimmer but for now it's working fine.
The preamp sounds stunning but i'm really concerned about too much current draw if i plan to build 4 4ch 1RU unit...i blew my little transformer so in the meanwhile i'm just getting a bigger one.
I've heard that the farichild fets can cause some trouble. But cannot get the ON semi fets for now...
Any help on this??
Any help on this??
