Finally getting time to build the PRR varimu... and I have a question.
Checked voltages on the power supply unloaded. Everything's cool except the bias supply for the TL074. I got 1.38 VDC, whereas it should be at least 1.5 and I think others in an old thread have mentioned 1.55 or 1.6 (Svart and PRR, respectively).
I understand that changing the LED could result in a different (hopefully higher/correct) voltage, but instead of sorting through a bunch of LEDs (of which I have none right now, anyway), what would the consequences be if I left in that particular LED? In other words, how critical is the bias supply voltage in this circuit?
Chris
Chris
