[quote author="aortizjr"]I have also heard of guys that use Inkjet glossy photo paper. I have a lot of the PnP so I haven't tried it yet.
But similar concept to coated paper.[/quote]
Yes, I use inkjet glossy paper, and it works fine. Probably it depends on paper brand a bit, I use Verbatim cheap paper, printing with cheap HP Laserjet, highest print density. Iron temperature is important, must be hot, so that paper turns a slightly brownish (burned?) after ironing it. PCB must be really clean. And take care with larger PCBs - preheat PCB, before putting paper on it, otherwise PCB expands after being heated, and traces get somewhat smeared on edges.
After ironing I throw pcb in water for some minutes, then paper goes off easily by rubbing with fingers. It is simple and cheap.
