EZ81
META - headphone amplification New
« on: November 07, 2007, 06:20:31 PM »
After some research about headphone amps, a little cleaning of the bookmark collection resulted in this META. Enjoy  :thumb:  and contribute :!:  :!:  If you think that certain links should be removed or moved to a different (sub-)category, please PM/email me or post here, i have not read all threads carefully.
;Matthias
META - headphone amplification (and everything else regarding headphones)
This is a meta-thread, made to allow you to keep track of the posts concerning this single issue. All should be contained in this first post - which is re-edited regularily. Everyone is welcome to reply with comments and pointers to things they consider relevant. This will be copy/pasted into the first post, if the meta-keeper finds it relevant. (We deeply dislike censorship, but here it seems necessary for the sake of overview). On a regular basis, a moderator will delete all posts but this first one, and bump the thread to the top.
headphone amps
schematics and circuit ideas
solid state:
designing headphone amp A preview on the next Gyraf DIY headphone amp design and discussion about some circuit details.
Good DIY headphone amp? Gyraf's tube headphone amp, NYDave's line amp, PRR's Tori amp. Lots of great stuff here.
Chu Moy Headphone Amp? with opamps
Using the THAT1646 As A Transistor Pre-Driver/HP Amp
Class-A Mosfet Source Follower
The most math I've seen... in a headphone amp project. (opamps)
simple headphone amp with opamps + transistors
Analysis of a certain class A driver (from a passive EQ) that will also drive headphones.
Gyraf Headphone box question (opamps + transitors)
Headphone amp output confusion (Tori Amp) PRR explains details of the Tori amp
headphone/guitar amp Has a nice "Estimated power versus impedance of several common headphone amp topologies"-graph
Jung Super Buffer
gain block idea
everyone loves headphone amps! output voltage, loading, power, ...
gar2520 as a headphone amp? Yes, it will work...
tube:
A tube headphone amplifier using 6080
Help needed for OTL Headphone Amp design
Small Line Amp (Tube) by NYDave.
1W Power Amp with 6922
Improved Tube Headphones Amp (ECC99 in SRPP, output transformer) by Ian (ruffrecords) NEW  2011-06-27
general discussion
crossfeed filter in headphone amps
complete projects
Tube Headphone Amps
Current feedback headphone amp with super regulators
Headphone amp with 0.000021% distortion
headphone amp with a LM386 low-power amp IC
http://www.pmillett.com/wheatfield_audio_ha1.htm A tube headphone amp.
interesting parts
LHoo33 and 63 "Damn Fast Buffers"
Experiences with BUF634 as line buffers?
http://focus.ti.com/docs/prod/folders/print/tpa6120a2.html The TPA6120A2 headphone driver IC from TI.
LH0002CH -- what is inside?
http://www.national.com/pf/LM/LME49600.html LME49600 - High Performance, High Fidelity, High Current Audio Buffer
commercial products/kits
should these be included?
headphone distribution/switching/monitoring/...
These are unsorted/checked yet
Headphone/Monitor switch?
passive headphone splitter with volume control per headphone
headphone distro system
wiring up headphone cues. a few questions...
Headphones form a power amp
headphone dist. amp design
Any schems for a monitor selector and/or heaphone amp?
headphone cue amps?
Passive Headphone attenuator?
headphone splitter amp
Headphone distribution box
quickfix headphone amp solution
http://voyager.celestial.com.au/~rosswood/diy/headphonedist/headdist.htm
other things of interest
Headphones and hearing damage?
external links
http://www.headwize.com/ HeadWize - A Headphone Resource Site
http://www.head-fi.org/
http://sound.westhost.com has some HP amp projects.
« Last Edit: January 02, 2015, 11:34:38 AM by Ethan »
gyraf
« Reply #1 on: November 08, 2007, 02:18:53 AM »
Good initiative!  :thumb:
I have a DIY-project coming up very soon - a simple-to-build universal headphone amplifier..
JAkob E.
dinesh
« Reply #2 on: November 08, 2007, 02:29:41 AM »
I have a PCB Ready for Stereo input 4 out headphone amp. :thumb:
James HE
« Reply #3 on: December 13, 2007, 05:55:01 PM »
This Meta should be in the Meta-Meta.
gyraf
« Reply #4 on: December 14, 2007, 04:15:21 AM »
Quote from: "James HE"
yea, off course. done.  :thumb:
Last post November 24, 2006, 11:53:54 AM
by SSLtech
Last post June 16, 2012, 02:58:26 AM
by zebra50
Last post July 08, 2013, 04:30:03 PM
by Moby
Last post March 28, 2019, 10:27:35 PM
by zaraxisof
