dustbro
AMS RMX16... distorted output
« on: November 12, 2007, 05:21:00 PM »
I came in to the studio today to find that my RMX16 was making a noisy/popping sound on the right side that was just about blowing up my NS-10's.
After pulling each card I found that the output card (DMX 44.3) was causing the problem. I totally recapped the card... didnt work. I swapped out the 5532's... still didnt work. then I replaced the tl071 and the noise stopped! the only problem I have now is that the right channel is now distorted no matter what level input it gets.
Anyone have an idea on what might be up?
TIA
« Reply #1 on: November 13, 2007, 12:50:14 PM »
David Kukla(studioelectronics.biz) is the go-to person for these if you need it fixed.  Maybe you could check out the input card if you want but these are quite the ***** to fix.  I hope you are using a decent desoldering gun like the Hako or better.
Good luck dan
sonicmook56
« Reply #2 on: November 14, 2007, 01:10:10 AM »
Did you try swaping the A/D cards?  Could also be the sampler card.
Sometimes it's just a bad ribbon cable somewhere, I would replace them all if they look a bit funkey.
« Reply #3 on: November 14, 2007, 08:00:55 PM »
Even swapping input/output cards if they are separate like the delay unit.  Also try cleaning all the contacts on the cards and ribbon cables.
mikep
« Reply #4 on: November 14, 2007, 08:38:24 PM »
i would say reseat everything.  alot of little problems disappear, and/or appear when you do that.  keep messing with it, wait! right there. don't touch it. thats my experience with the DMX.
dustbro
« Reply #5 on: November 19, 2007, 04:19:02 PM »
Thanks for the replies! This thing is on its way to David for repairs.
« Reply #6 on: November 19, 2007, 06:13:16 PM »
BTW, he sells optos for the LA2A's at 15% discount to forum members too.
Last post January 24, 2006, 10:43:38 AM
by John Noll
Last post May 26, 2007, 02:36:10 AM
by gyraf
Last post May 21, 2019, 02:56:55 PM
by pucho812
Last post March 14, 2021, 05:48:39 PM
by radardoug
