andre tchmil
Eventide H3000,back on duty,mod for analog bypass ?
« on: November 24, 2007, 03:59:47 PM »
Hi all,
I have a blackface H3000 here.
Everything works just fine, except for the large LCD display backligh which is very weak.
I can adjust the brightness with the "Function" parameter, but it's still to dimmed.
Anyone had to repair something like this before ?
thanks
Larrchild
« Reply #1 on: November 24, 2007, 04:54:30 PM »
There is a .1uf cap, I believe that goes bad in the display backlight circuit board.
Look for a largish one.
sintech
« Reply #2 on: November 24, 2007, 06:39:31 PM »
Hi Andre,
I've always wondered how to adjust the screen brightness on the H3000 :) any chance you could explain the method for me?
many thanks in advance.
andre tchmil
« Reply #3 on: November 24, 2007, 07:08:10 PM »
in function mode, spin the dial wheel.
andre tchmil
« Reply #4 on: November 24, 2007, 07:10:36 PM »
Hi Larrchild.
Thanks for the help; but I don't see any cap around the LCD.  :?
I Measure around 5V at the backlight.
Yes, I did the ROM reset, etc.
Larrchild
« Reply #5 on: November 24, 2007, 07:23:45 PM »
They use a small switching supply to generate the backlight voltage.
The cap is part of the oscillator. Look for a small ferrite core transformer. It's near there.
The voltage on the backlight is much higher than 5v.
SSLtech
« Reply #6 on: November 24, 2007, 10:41:09 PM »
Quote from: "andre tchmil"
It's actually the contrast, not the brightness, IIRC.
Keith
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
Bookkeeper
« Reply #7 on: November 24, 2007, 10:43:32 PM »
It is Optrex DMC40267-yu-neg display (U1). Back light is connect to pin nr. 15 (ground) and 16 (resistor R23 5R6/1W). This resistor is directly coupled to +5V DC. On pin 15 should be 3.9V/0.2A.
LCD contrast signal is feed from U3 (74HC174) to Optrex pin nr. 3 (VO).
It probably means, you can'n change the backlight, but you can change the contrast of the display. I guess...
Milos Fiser
andre tchmil
« Reply #8 on: November 25, 2007, 04:25:46 AM »
Quote from: "SSLtech"
Keith
You're correct. It's the contrast adjustment, which is perfectly working on my unit.
sintech
« Reply #9 on: November 25, 2007, 05:29:37 AM »
Keith
This function doesn't work on my unit.. I guess it's stuck on full (grey face SE model)
andre tchmil
« Reply #10 on: November 25, 2007, 01:43:10 PM »
Problem solved.
Replaced the Backlight.
andre tchmil
« Reply #11 on: November 26, 2007, 12:56:09 PM »
While the baby is open,
would it be possible to bypass the analog in/outs and go direct via spidf or aes ?
in a simple way . :oops:
SSLtech
« Reply #12 on: November 26, 2007, 03:53:21 PM »
Nope.
Sorry... That's quite a big deal. Not least clock-stripping and then clocking the unit from that.
Just stay analog... you know it makes sense! :wink:
Keith
Quote from: PRR
Last post July 24, 2012, 10:54:35 PM
by Brian Roth
Last post July 25, 2007, 11:00:06 AM
by SonsOfThunder
Last post November 10, 2008, 01:23:50 PM
by sahib
Last post October 15, 2009, 01:42:35 PM
by tubejay
