Question about the jensen tube output stage.
ChrioN
Gothenburg, Earth
I'm considering building one on these preamps:
http://www.jensen-transformers.com/as/as054.pdf
and use this output stage:
http://www.jensen-transformers.com/datashts/10k611m.pdf
But I don't want to use 4:1 (or 8:1) stepdown. Can I use a 1:1 transformer for the output?
Depends on what you plan to feed. If you'll only be feeding into 10k inputs (soundcards, etc.) then a 1:1 transformer will work okay. If you intend to plug into a 600 ohm input (like an old compressor) you need to use a 4:1 transformer, because the output tube doesn't have enough current to drive a 600 ohm load.
Peace,
Paul
