Quad Eight 2520 style gain block ....PCB Help
Gwaggin390
Hi all,
been fiddling with a Quad Eight EQ PCB and thought about making the gain stage
"pluggable" so i came up with a rough design for the "classic" Q8 gain stage on a 2520 style board. Note that the Q8 usually uses +/- 24v or +/- 28v
Fist question is, how does it look? anything i should specifically stay away from as far as component placement? Already have some ideas to make it better.
Board is looking from the top down,
Left side is + then - (top to bottom)
right side is Out, V-, C, V+ (top to bottom)
also, where does one buy the pins to go into the board? and is the female also available to make it truly pluggable?
PCB--(can't get the pic to just load...any suggestions?)
http://img.villagephotos.com/p/2007-11/1288762/Q82520.jpg
Orignal Q8 gain stage (Mic pre is very similar to the API 312)
http://img.villagephotos.com/p/2007-11/1288762/q8_micpre.jpg
Hi P,
i found the MillMax stuff on Digikey, but the part #'s don't seen to work when i punch them in and i can't find them on the catalog pages.
are they special order?
Might you know the dimensions? i could look for equivalents in the catalog
thanks
thanks peter,
it's just a rough idea for now, i don't have exact sizes yet
the pc i'm using is a piece of junk and i can't get much to run on it
(i'm a mac guy) So that pcb design was made using pcb123 software which is only ok at best
