pucho812
O.k. this is the last thread on this topic. But I am sctraching my head on this one. That ampeg I am working on, I got a schemo... I tested it. the pre amp works great. The power amp has issues. It's noisy as well as triggers the limiter to over limit. That causes the sound to drop out. I used a scope on the power amp online and it has noise as stated before. I ran a scope accross the power amp and it is bad at all points. Meaning I get my test sine wave with noise at all point testing There are 2 resistors in it that get super hot. I would imagine they would burn up if they were not 10W ceramics. Anyway this has lead me to a bad transistor or bad transistors. Anyway when testing out the transistors, I found 11 that are acting dodgy. I do not have a transistor testor so I been testing them via the diode checker method with my multimeter.
you test like this. By using a diode tester on a multimeter, when you run your tester leads accross the transistor you should get these results
The base-emitter (BE) junction should behave like a diode and conduct one way only.
The base-collector (BC) junction should behave like a diode and conduct one way only.
The collector-emitter (CE) should not conduct either way.
Either my testing is dodgy or there are actually 11 transistors that need to be replaced.... Or am I tripping and only have one bad trasistor which happens to be the first one and is messing it up for the rest of the circuit?
