Pultec Inductors again...
ognam2
Berlin
This has been discussed several times yet, but the problem is, that the suppliers are changing their product lines all the time. From this one Shopping list, that I found in any other Pultec thread, I know that the conductors should be 22mH, 47mH and 100mH. But what about it´s resistance. I also know, that the resistance is responsible for the "Q". But whitch value´s should I take to have a nice musical sounding equalizer? I saw some very expensive inductors at Sowter which were looking like vintage ones... Is that worthwile for 56 EUR? Is there anything else that I should know about my inductor choice?
Thank you....
Jonas
Which Toko's to use? I have heard that they sound harsh.... I have been trying to get a Wlco BSL group order to happen for my API 553's, they are reputed to actually sound good....but min order of 100. At a few dollars each it would be much less than buying the custom wound multitap inductors
how do you wind over 20' of extremely thin wire around a torroid core 3/4" in diameter? I can get the cores and wire locally, but I can't find a DIY way to wind it. I know other types of cores will work, but how close will they sound?
I was thinking about getting the cinemag but now I feel like winding my own even if it takes a day to get it right. A Fluke for the inductance measurement should be OK right??
Could somebody point me to the dimensions of the torroid and the wire gage.Also any link to where it could be bought would be great
Also Drpat it would be real cool if you tell us what type of caps they are using for the amp section: is it PIO or just old paper caps.I suppose you dont know what is inside the filter section.I checked some of the caps of that era and some of the filter values like 0.0082 seemed to come only in ceramic disc
thanks
nielsk,
there is no easy way to diy it...there was a post some time ago of a co. offering a diy xfmr/inductor kit-- they supplied a core and wire. they also showed a photo of the winding device
winding is the hard part--the more uniformly wound the better.
take a popsicle stick/tongue depressor (that will fit through the center of the core, accounting for reduction of opening as wire is added) and whittle u-shaped notches at both ends,wind your 20' onto this long thin bobbin.
use the popsicle stick bobbin to wind around the core...
You need to know the perm or Al number of the partucular core you are using so you can calculate a ball park number of turns to get you to the first stop.
If you use too many turns, you will have too much wire to wire capacitance, which can accumlate to the point where the high end goes on thru anyway, at least 1/2 cycle, the other half goes thru the cap, so you will have an "interesting" eq curve.
DrPat,
Thanks for the answer.The most practical answer I've got so far and believe me I've asked so many Pultec owners and nobody knows thier Pultecs from their pants.
In another forum you talk about 3 caps which affect the sound drastically .What are those? Are they the Aerovoxs in the amp section.I am trying to do some calculations to acheive the dcr you've measured using available ferrite torroids
Audio Cyclopedia regarding toroidal coils, as recommended for EQ construction:
...circular core composed of molybdenum permalloy dust mixed with a plastic binder, compressed into a doughnut under 200 tons-per-square inch. By the use of this type winding, coils with a Q of several hundred are possible. Efficiency is extremely high compared to other designs.
been winding a ton of toroids lately on our machine at work.
learning some cool stuff.
1) wire pitch affects the toroid.
In other words, lets say you need 1000 turns wound on a core.
How many times do you circle the core?
Three? Five?
It makes a difference, very slight, but it is there.
How would this affect sound?
Thats when you hop on the bench to find out.
this machine lets you program in any wire pitch you like, via a keyboard.
2) wire size
dcr will change depending on the wire size.
this combines with the non linear properties of your average inductor to produce yet, another effect.
if you want a transformer to put out say, 10 volts max, and exactly 5 volts at half power, you need to pick the wire right.
distortion due to non linear voltage curves can be minimized by doing more bench work.
unfortunately, the formulas only take you so far, so you hop on the bench, which saves time anyway, as the theories are always opposite the results.
so now you have two tweaks to play with, which combine to form, say, 4 wire size possibilities, and maybe 4 more pitch possibilities, so multiply to get 16 different inductors by using the same core, and the same turns, arghh!
:mad:
but fortunately, a lot of the combinations overlap, so you only end up with maybe four distinct inductors for the same core and turns, still, I'm jus sayin...
So in order to duplicate the original Pultec inductor, I am afraid you would have to look at the winding technique and measure the wire, which means, gulp,...a dissection on a very rare and expensive part.
kh, how did you get the turns from your orig P inductors?
PRR method?
Also, do not forget the wax.
Every company had their own potting formula, which could tweak the high end.
Again, these are microscopic tweaks, but when you are trying to duplicate the original mojo, you try to get as much info as possible.
Also, list the way you get the Al number, because it varies depending on meter used, and turns used.
You tend to get a better Al as you add wire, up to a point when the dcr starts to drag it back down.
but veve have vays of getting information
it might have been "pie" wound.
this is a technique you can find on the web.
it is used to minimize C so that your high end has a nice bell curve.
you wind a bunch of turns, then you rotate the core 180 and wind another pie.
then you only get to roate 90, but then you get to rotate 180 again, but now this section is right next to the start, and on and on.
you could wind the low end all as one pie, then spread out the high end windings.
i do not think any special high end audio winding was going on, as this was a cheap telephone eq.
you could also try 120 120 120.
this would have equi distant voltage gradients, which might require a bench experiment to verify.
you can machine wind pies.
you just set a small pitch, wind a pie, then hit stop, rotate the core with the L or R button, and start winding again.
i do not think that those toroids were hand wound.
possibly the antiquated toroid winding machines made it look that way.
For new comers... here's a link to my builds:
My 3 DUAL PULTECs - EQP-1a3 - Solid State
http://www.groupdiy.com/index.php?topic=29742
CJ,
Pat would have to give you more in depth details about how he did it but I know he didn't unwind one. I will try to to explain as much as I can.
From what I remember him telling me:
He took apart the can & WAX
Measured EACH Cap & Winding with a good (Freshly calibrated) Meter... I think it was an HP.
Measures the wire gauge = 34.
Then he wrapped the cores (over the original wire) to find the AL Value = 876
Then he started wrapping several different inductors until he found one that matched his magic #.
Then... he "Listened" to his new inductors (& if I'm correct, also ran test sweeps) to hear how close he was.
He said his second attempt was "Spot On" & couldn't tell or measure a difference.
I definitely remember him telling me that his first attempt didn't sound as good as his 2nd one & so on.
I remember asking him about this & he said there didn't seem to be ANY method to "How" the original was wound... so when I wound mine, I remember lapping several times... aprox between 6-10 times maybe.
BUT, the ones I wound sound KILLER & when I run sweeps on the left & right channels, the Frequency's & Plots are EXACTLY the same.
They are by far my favorite ones.
& I have to be honest... I was skeptical (not about Pat or his info) about MY builds/wraps.
Myself, I used an AMPROBE LCR Meter.
You have to be careful when using ANY meter to test as your winding -
Because - The wire on the "Popsicle Stick" has inductance too :!:
AND... it changes AS your winding & losing wire on the stick & gaining on the core.
SO... Measure your STICKs Henries FIRST :!:
I just used the "Force" (Like Luke Skywalker) after this to guess what that value was doing to my CORE reading.
WAX!!!
Very interesting about the wax...
I didn't use wax... I used HOT GLUE to seal mine & I pray that it doesn't effect them, over time.
I did this (Mainly) because it's all I had & could think of that would protect & seal them from damage... especially the way I strapped them down.
I took care not to torque them down hard at all with the straps!
Also, after I finished winding one of them... one of the taps in the middle broke off & every tap above it had no reading!
:shock: :mad:
So, I got out my big ass lighted magnifying glass & took a tooth pic & gently dug into the windings to find the break, pulled it around & re-soldered it to a new wire & all was good... thank GOD!
This took about 2 hours to fix & I wasn't going to take any more chances with that happening after all that hard work, so I grabbed my hot glue gun & that's all she wrote.
The Hot Glue made me nervous at first because the HEAT changed the inductance... but after the glue settled, so did the inductance, back to normal. :green:
With all this knowledge here & CJ's winding machine... maybe (if someone could find some good cores) CJ could make some :?: :wink:
OK, I'm out.
I just wanted to contribute with the construction I did some time ago.
You can see that the inductor is wound on a toroidal core. (120°)
This is the LINK
There are some sound clips to compare.
:musique:
Respect,
Val.
[quote author="khstudio"]Looks like a few hundred winds & larger wire gauge... I'm guessing ferrite cores?
http://www.groupdiy.com/index.php?topic=29742[/quote]
Thank you!
Yes, it's a high quality toroidal core, material N30 (ferrite),
wound with 0.35mm insulated copper
150mH inductor tapped at:
27 (0.58)
33 (0.66)
47 (0.79)
68 (0.95)
82 (1.05)
150(1.45)
() figures are DC resistance values in ohms.
Distributed capacitance: 2.2 pF
Can you tell us more about your original ferric powder cored inductor? How many turns, which wire gauge, DCR's, what's the core Al, etc.?
Where did you find the ferric powder cores?
Respect,
Val.
