Hey the ease & convenience of this diagram begs questions
[ from my mind ]
http://www.jensen-transformers.com/as/as016.pdf
Such as i presume it would be better to switch windings instead
of adding resisters to change impedance , but is that so ?
or how would one add a pot instead of the resisters ?
If some are likely to quote that the xfmr " reflects " back impedance
you may think it doesn't matter but on some mic/pre combos it makes a big difference
changing the input impedance [ xmfr to xfmr ? ]
The jlm 1272 hotrod diagram shows phantom going to the center tap ,
but for best common mode rejection , would it be better to use 6k8 resisters matched
as tight as possible in case the windings are not as close ?
tia , answers will help my upcoming pre projects
regards Greg
[ from my mind ]
regards Greg
