living sounds
Hi everyone,
I'm building the PRR Vari-Mu on variboard using Kent's updated schematics/PCB layout:
http://www.conditionedresponse.com/DIY/C5/index.html
Since I live in europe I've got to use two transfomers, one 230-12 for the heater, bias, opamp supply and one 230-24 in reverse for the B+.
The B+ voltage is alright (reading ca +104 V DC), the bias seems fine (ca. +1.5V, though it sometimes drops as low as 1.3), but I'm getting much lower values which change after some time for the rest, namely
-12,2-13,5 V DC at the -16V rails
+ 1.3V DC at the + 16V rails
+1,7-1,3 V DC at the 12 V heater supply
I'm also reading some AC on those rails now and then (it's not there all the time).
I've checked everything 10 times now and even changed the rectifier for the 12V AC supply, but cannot get behind the problem.
I'm using a 4.700uf cap instead of the 5.000uf, but also soldered in a 300uf cap in parallel for testing, which didn't change anything.
Could this be related to a faulty cap?
Also, the LED glowed up a little at a time, but now doesn't, it's getting 1,38 V DC...
Any help would be much appreciated, I'm at a loss now...
Thanks alot!
Gregor
Thanks alot!
Gregor
