voltasonic
New member
Hi Jakob,
I finally registered to this forum after naggin you for sometime in the past with my e-mails. :grin:
I have moved on from the G1176 to the GSSL now.
So, according to my topic, what should be removed from the schematic, and what should be added (if there's any) to the schematic?
(I'm using LL1540 and LL5420)
What I have in mind is, that I can safely remove the input part before the 15K* resistor (add a switch for bal/unbal), and also remove the output part after the sidechain VCA.
Am I correct? Can you or someone, pleeeease put an enlightment to this issue? :grin:
Thank you.
Regards,
Brian
Thank you.
Regards,
Brian
