anyone know where I can find an EAO switch # 001-121-825
pucho812
third stone from the sun
Our beloved SSL Tech will or should recognize that as the SSL onboard track arming for an 4000 console. The closest I can find is EAO 001-121-025 which would work in terms of being wired up and working but not quite sure if it would fit the button cap and such.
anyone?
I don't know about this switch. However I was looking for a replacement EAO for an MCI 416a. I contacted their UK distributor, & it seems they do quite a range of legacy items from their range, which I couldn't find in the catalogue. It may be worth contacting the US distributor.
Just for your info we stock the following switches (but not the caps etc);
01-281.0252 Series 01 Square Single Pole C/O Latching
01-151.0252 Series 01 Square Single Pole C/O Momentary
01-282.0252 Series 01 Square Dual Pole C/O Latching
01-152.0252 Series 01 Square Dual Pole C/O Momentary
They are used on various AMEK consoles.
Colin
www.audiomaintenance.com
does anybody know where I can get caps for the Series 01 Square switches ?
I have a few dozen of the switches (and I like them very much), but only a few white caps left :cry:
it is a shame EAO doesn't make this switch anymore :roll:
[quote author="[silent:arts]"]does anybody know where I can get caps for the Series 01 Square switches ?
it is a shame EAO doesn't make this switch anymore :roll:[/quote]
Are you sure they don't make it ? like I said in the other post they do more legacy switches than is apparent from their brochure. I suggest phoning you countries distributor.
[quote author="Rob Flinn"]
I suggest phoning you countries distributor.[/quote]
I did, and they said they still can supply them....
[quote author="radiance"][quote author="Rob Flinn"]
I did, and they said they still can supply them....[/quote]
I'm glad to heart that, I thought that might well be the case !
