G7 mic capacitor value question..
tamtamstudio
Italy
In power supply are signed 2 x 1000mF /35V. In the schemo is 1x 2200mF / 25V, what's the best solution?
What's the best way? It's the same?
:shock:
Several studies I have seen show a slightly better response from 2 caps in parallel, but I doubt it is critical in this allpication. By the way, I think you mean uF not mF.
:wink:
Thank you guys, i did it.. 1x 2200 u(m)F..
Can I use also 2,2uF polyester also for stab in the mike instead 1uF like printed in the PCB?
