Your pin #s sound right for 150 input connection with CT and one side of sec grounded. (EDIT: SEE NEXT POST) I'd leave it there; remember this is an unloaded secondary and 150 references the suggested drive Z from the mic, not the actual load presented to the mic. Listen both ways if curious; it will depend on the mic which you like best probably. Input is connected as a single winding with center tap (probably grounded) covering roughly 30/150/600. That makes 9 pins counting 2 for secondary. Without having opportunity to look at my reference materials ATM that would suggest faraday shield tied internally to case. Polarity should always be checked on any of these old modules. Usually the manuals give reference, but field hacks abound.
It gets even trickier. There are model #s, Master Index #s, drawing #s, and replacement part #s. Any single RCA transformer may have an RCA drawing #, a manufacturer # (ADC, Hollytran, Kenyon, Langevin, Stancor, Thordarson, UTC, etc), and a replacement part #. The replacement #s are only found in the manual parts lists, and do not reference the MI #s, so you have to have several pieces of evidence before you to compare and ID. The MI #s for whole units are available in the catalog price lists (if still found in the back pocket), though you'd have to find one from about every 3 years for 45 years, and they seem to sell in the $50-$400 range. The required investment makes free revelation of hard-earned data unlikely. I've only seen one replacement parts list and it was from about 1972, and it was not fully revelatory either. I would seriously doubt any company has held on to 40-60 year old custom part #s as companies have changed hands.
