fum
Math geeks and panel graphics unite
« on: October 01, 2004, 08:34:35 PM »
Hey there.  I'm workin on a decent way to print out scales ( other than buying a full scale graphics app like Corel Draw)
I've got the shell of an application created that will save stuff out to a jpg file.
I need help with the formulas to calculate the positions in an x y coordinate system for the scale values, for a given radius, based on degree.  If you can give me a rough formula, I can take it from there
For example:
Given radius of 30 , if you wanted a scale in 30 degree increments, I need to calculate x y coordinates where to place the graphic objects, given that the center of the scale will be 0,0.
Once I get this part going, I'll add on the other features to make it cool, and put it up for people to download.
Any help out there?  I'm googling at present, but thought I'd ask =)
Regards
ju
mcs
« Reply #1 on: October 01, 2004, 08:42:34 PM »
Don't save to jpeg - that's my advice. jpeg is not a format for graphics - it's for photos.
Saving stuff in PostScript is VERY easy - you can even calculate the scales etc. in the PS code. PostScript can be imported in a lot of drawing apps, you can open it in Photoshop and you can convert is to PDF format without loosing any quality.
I can help you with PostScript programming (I could also help with jpeg stuff, but I don't like that idea :wink:).
Best regards,
Mikkel C. Simonsen
fum
« Reply #2 on: October 01, 2004, 09:03:48 PM »
postscript should be fine, or perhaps a vector graphics format.
Regards
ju
mcs
« Reply #3 on: October 01, 2004, 09:17:45 PM »
Quote from: "fum"
PostScript is a vector graphics format - as well as a programming language :cool:
But do explain your idea a bit more detailed - what do you want to do?
I would probably make something web-based. Use a form to input values, and then spit out EPS, PDF or PNG files.
Best regards,
Mikkel C. Simonsen
fum
« Reply #4 on: October 01, 2004, 09:23:01 PM »
the idea is to write a java application(will work on any platform this way) with screen divided into two panels.  One to vary the parameters of the scale, and a display on the other side to show you realtime what your getting.  Variable radius, degrees, editable scale values, etc.
Once you've got your scale the way you like, save it to the file format of choice, from there you can import it to your application of choice.
One good option would be HPGL, for those who use Front panel express.
I've been using Photoshop, so any format it supports gets me there.
ju
CJ
« Reply #5 on: October 01, 2004, 09:29:54 PM »
Darn I used to be able to convert Polar to x,y in my sleep.
 :sad:
I'm thinkin  tangent and unit circle.
wrong again!
 X= R*cos(Theta)
Y= R*sin(Theta)
r is radius
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
mcs
« Reply #6 on: October 01, 2004, 10:19:24 PM »
I just played around a bit...
This bit of code:
Code: [Select]
/Xpos 100 def
/Ypos 100 def
/outrad 40 def
/inrad 25 def
/steps 9 def
/stepsize 300 steps div def
/deg 300 stepsize 2 div sub def
/Tegn
/deg deg stepsize add def
Xpos Ypos moveto
Xpos Ypos outrad deg deg arc
stroke
} def
steps {Tegn} repeat
1 setgray Xpos Ypos inrad 0 360 arc fill
showpage
Produces this scale:
No hard math needed :green:
Best regards,
Mikkel C. Simonsen
fum
« Reply #7 on: October 01, 2004, 10:50:42 PM »
ya gotta think like a computer for that one.   looks stack based. =)
we'll see what I come up with once I get the chillins sleepin
ju
fum
« Reply #8 on: October 02, 2004, 01:29:12 AM »
Okay,
I've got something, it's gonna take me a few days to make it cool, but I've got the rough drawing mechanism worked out to so that I can print the scales on the screen.
After spending a couple hours or so working on this, I've decided that using PostScript is  cheating, as it really was designed to do this kinda thing  :grin: Good developers cheat  :thumb:
I'm ending up using radians in some of my calculations, and I honestly didn't know what a radian was when I started.
Stay tuned
ju
rafafredd
« Reply #9 on: October 02, 2004, 01:33:31 AM »
I think it´s a great idea to make this tool. It´s definetly needed...
CJ
« Reply #10 on: October 02, 2004, 01:39:05 AM »
Compare your printed results with what you are after.
I have done hours of graphics only to have them mis-scaled by the printer.
That way you catch it before commiting your expesive Lazzertran or whatever medium you use.
 :evil:
fum
« Reply #11 on: October 02, 2004, 02:03:03 AM »
I hear ya.  I always print tests to paper, and hold it up to the light with the panel behind to make sure it looks spiffy.  :grin:
I'm doing panels for a pair of SSL clones at present, and I've got the words all lined up, but I want *****in scales around my knobs ( now don't be talkin about the scales around my knobs  :shock: )
ju
fum
« Reply #12 on: October 02, 2004, 02:12:49 AM »
okay, here's the first output as jpg ( sorry mcs, already had this part figured)
Nothin fancy, but.....
mcs
« Reply #13 on: October 02, 2004, 08:31:13 AM »
Quote from: "cjenrick"
Which is why PostScript is great - the calculations are done BY the printer, so nothing gets "distorted"...
Best regards,
Mikkel C. Simonsen
mcs
« Reply #14 on: October 02, 2004, 08:38:38 AM »
Quote from: "fum"
Yes, PostScript is a great mind-exercise language :wink:
How does your code work? Do you calculate the start and end coordinates for the lines? If so writing that in PS or HPGL format shouldn't be too difficult. But adding text would be much easier in PS than in HPGL...
Best regards,
Mikkel C. Simonsen
mcs
« Reply #15 on: October 02, 2004, 12:01:12 PM »
Quote from: "mcs"
I had to see how difficult it would be do make a CGI version. It wasn't difficult at all - it took half an hour... Here it is: http://stiftsbogtrykkeriet.dk/~mcs/Scale.html
EPS version only though...
Best regards,
Mikkel C. Simonsen
daArry
« Reply #16 on: October 02, 2004, 01:00:56 PM »
nice1 :thumb:
rafafredd
« Reply #17 on: October 02, 2004, 01:12:48 PM »
Mikkel, you are fast!
Can you implement the numbers?
mcs
« Reply #18 on: October 02, 2004, 01:14:32 PM »
Quote from: "rafafredd"
What numbers? Numbers next to the lines? I can try...
Best regards,
Mikkel C. Simonsen
rafafredd
« Reply #19 on: October 02, 2004, 01:21:57 PM »
yeah, like a DB scale...
You know, something like starting number and steps, so we get a dB scale.
Lets say -20 starting and 5db steps, in a 12 position scale would output:
-20, -15, -10, -5, 0, 5, 10, 15, 20, 25, 30, 35 dB
Got that?
Last post April 04, 2008, 06:01:36 PM
by okgb
Last post October 31, 2009, 07:49:33 AM
by dmlandrum
Last post January 21, 2011, 10:26:28 AM
by SimonB
Last post September 26, 2011, 05:30:22 AM
by Kingston
