This is very impressive. After having done scales in Corel this will make life much easier, thanks.
Whenever I have needed to draw something "difficult" like this, I have often written it in PostScript. I have even done graphics for websites that way...
Tick shape: for example a dot, specifiy diameter for major tick and a different dot diameter for minor tick.
What's next? Pink elephants? :green:
Something like this:
Do you want dots or circles (or both)?
The subtics are half size as it is now. Either half length or half diameter. Is that OK?
Radii in mm or inches instead of points ? - would that introduce scaling errors to postscript ?
I could multiply with 2.83 to convert from mm to points. That would only cause a small error.
Text instead of ticks ?
I will probably make no ticks an option - you can still specify the text for the lables- That option isn't ready yet though...
Yeh, i know, the crazy swedes are never satsified... :grin:
I'm not easy to satsify either :wink:
Best regards,
Mikkel C. Simonsen
