Passive EQ from Opamp Labs circuit
craigmorris74
GDIY Supporter
benton, ky
I was building an Opamp Labs 109eq like in the top schematic below. I could never get the amp section to perform properly, so I'm thinking about just unsing the EQ section in a passive configuration. I hacked up the origian schematic and posted it below. Does this look like it will work? If anyone sees anything blatantly wrong, let me know.
Craig
Somehow i think you'll have to create an opamp circuit , maybe
with opamps and wire in a simular way
It looks a bit like the circuit Scott Dorsey had in Recording mag a while back .
or the was Forssel designed the SST-1 eq [ see it in the block diagram ]
what okgb said you need an opamp w inverting and non inverting inputs, look at forssels eq pointers or api eq schematic
