DIY midi controler
frob
any sujestions on doing a midi transport controller. i would like one that does just transport couldnt be to difficult. any one with any midi experiance?
How about USB instead of MIDI?
If you can use hot-key commands from your keyboard as transport controls, you could nip the circuit board out of a cheap/used USB keyboard and wire it up to a few push-buttons, like this...
http://chrishuntdrums.port5.com/remote.htm
That guy did his specifically for use with n-Track. But, it looks like the general idea ought to work with just about anything that can be controlled with keyboard shortcuts.
~ Charlie
I may also look in to Digital Projects for Musicians by Craig Anderton which I believe is sort of a step by step midi computer, controller, thingy....yeah.
Aaron
Audio Cowboy
_______________
Audiocowboy.com
This is a little different in that it's USB, but could be very useful:
http://www.hagstromelectronics.com/keusb36.html
The advantage of something like this over connecting pcb tracks is that it allows you to program a combination of keys from a single button, so you could add a button to your transport that does Copy (ctrl/cmd)+C, for instance.
If anyone knows another way of doing this (key combinations), please post... :wink:
Dan
There is also the X-Keys USB Matrix Board http://www.x-keys.com/custom/xkmatrix.php with a 16X8 matrix, for a total of 128 keys for US $59.95.
elco
