Glue?
tomelectro
Los Angeles
Anybody know what kind of glue I should use to stick kynar wire to a circuit board? I've just added balanced input chips to some Ward Beck EQs, and need to dress the connections. I've tried super-glue, and hot glue, and though they both work, neither seems optimal. I've seen beautiful examples of SSL boards that were factory modded with kynar (wire-wrap) wire, and wonder what kind of adhesive they used. Anybody know?
for that kind of work, ive had good luck with clear ge silicone ii rtv, the *noncorrosive* kind. ive found it at home depot. shop carefully because other kinds of rtv might contain acetic acid and are corrosive.
Quite a few factory mods with that wire are affixed with a specific Loctite cyanoacrylate. It had a primer, adhesive, and instant-cure spray in a convenient package. I don't recall the part number.
-Dale
I tend to use fast setting (1 minute) Araldite type epoxy 2 part resin glue. Fix the wire with adhesive tape temporarily - then apply a few glue 'spots' at intervals along its length. Neat and quick!
