Sourcing Toggle Switches
stitch-o
MA/PA in (not so) good ol USA
I'm trying to find a high quality DPDT mini toggle switch.
Anyone have a good source besides radio shack?
If the switch is in the audio path,
the quality of the switch will be important?
thanks all!
rtfm etas
electronics supply co.--farnell, newark, mouser...read data sheets for info on contact material (gold, bronze,etc) and intended application; I've never really delved into switch data sheets, but there are relays specially designed with for communications level/type signals and there may also be special low noise, low contact resistance switches. I've never had much problem with run-of-the-mill switches--yet.
I think I might go all out and get a 2 pos goldpoint switcher...:thumb:
the switch is for toggling between different 2 x types of output transformers so it sits right before the signal goes out the door.
btw what does "rtfm etas " mean?
no Marty, here it means "read the f'in Metas".
'tis not meant to be rude, there is too much for a newbie to read, but one must RTFM --sooner and more often,the better
Nah--line level +4dB don't need too fancy a switch. it's the real low level signals that will benefit most from an absurd switch
