JohnSuitcase
Member
I'm going to build a passive summing box, with 8 stereo channels, and 8 mono (so 24 channels total.)
I have two questions:
1.) What value resistor is optimal? I'm looking to do something similar to the Forssel Tech thing. I was thinking 10k, originally, but I see 5k on their schematic, and some people have suggest 1k?
2.) Do I need to use a different value on the mono channels? Obviously, I want to avoid crosstalk as much as possible (from the stereo channels,) but I also want the levels to be in the same range as the stereo inputs. The mono channels would be for things like lead vocal, kick drum, bass guitar, etc, that the user might want to run through an outboard eq or compressor, but not have to use two channels, etc...
Thanks for the help, I've learned a lot on this board, but couldn't find (or understand) the answer for this little thing...
