rbaker
7602 input transformer change, cap value across secondary?
« on: February 20, 2008, 12:58:48 PM »
I'm changing out the chameleon 7602 transformers with carnhills.  I've read that I should put a 150-200pf polystyrene across the input transformer's secondary.
When I took out the chinese version from the 7602, it has a 1000pf.
Any idea why the change or what different it would make?
rascalseven
« Reply #1 on: February 20, 2008, 03:21:57 PM »
When using a Carnhill mic input use a 180pF polystyrene across the secondary.  If you're also swapping line input trafos, the Carnhill line input should have a 1500pF (1n5) polystyrene across the secondary.
I wouldn't concern yourself with what they're using with the stock iron.  Stick to the above values for Carnhill (or St.Ives or Marinair) components.
That should be a nice little box when you're done!
:thumb:
JC
"If you dig the gig, do it. -But listen to the signal, not the person talking."  -Keef
rbaker
« Reply #2 on: February 20, 2008, 07:06:14 PM »
Thanks Joel...
I actually changed the 2n3055's a long time ago (they use ST micro)
I bought some ON Semi's and some nos motorolas and spent a good amount of time listening to them.
They were close but I think I was able to pick the motorolas over the ON semis 80% of the time.  Both were definitely better than the ST in there.
I also just changed some of the electrolytics to tants
I believe the bc184c's they use are motorola.  Do you think it's still worth it to change them out?
Next I think I'm going to make a new front panel.  :)
Last post July 11, 2008, 01:14:13 AM
by dinesh
Last post March 17, 2009, 10:15:09 PM
by JohnRoberts
Last post October 04, 2016, 10:50:59 AM
by thomasdf
Last post October 07, 2019, 08:02:57 AM
by abbey road d enfer
