7602 input transformer change, cap value across secondary?
rbaker
Los Angeles
I'm changing out the chameleon 7602 transformers with carnhills. I've read that I should put a 150-200pf polystyrene across the input transformer's secondary.
When I took out the chinese version from the 7602, it has a 1000pf.
Any idea why the change or what different it would make?
When using a Carnhill mic input use a 180pF polystyrene across the secondary. If you're also swapping line input trafos, the Carnhill line input should have a 1500pF (1n5) polystyrene across the secondary.
I wouldn't concern yourself with what they're using with the stock iron. Stick to the above values for Carnhill (or St.Ives or Marinair) components.
That should be a nice little box when you're done!
:thumb:
JC
Thanks Joel...
I actually changed the 2n3055's a long time ago (they use ST micro)
I bought some ON Semi's and some nos motorolas and spent a good amount of time listening to them.
They were close but I think I was able to pick the motorolas over the ON semis 80% of the time. Both were definitely better than the ST in there.
I also just changed some of the electrolytics to tants
I believe the bc184c's they use are motorola. Do you think it's still worth it to change them out?
Next I think I'm going to make a new front panel. :)
