Snatchman
Hello. As you may know (or not.. :green: .), I have a Tascam M-2600mkII console. Even though I've had some minor problems with the Master section ( bad fader, scratchy control room pot, etc.) it's all been tolerable until now. I'm noticing the bottom end of tracks sounding thin and soft. Seems like the volume is not as loud at the same level I normally monitor at. Also, when I power up the console, there's this fax machine type sound coming out of the speakers, headphone,etc. and the buss and stereo LED's light up about 1/4 ways up for about 30 seconds then dissapears. Everything works ok after then. This has been happening awhile. Now I'm hearing a loss of bass response of tracks played from my HD24-XR and also recordings played back thru the external inputs into the control room.( CD player).. Where would I start looking for the culprit for these problems? Thanks.......... :?
