TomWaterman
D-AOC PCBs - the building and help Thread
« Reply #60 on: March 06, 2008, 03:39:48 PM »
Hey thanks, that makes a whole lot more sense - I wasn't 'seeing' a threshold.
I'll label mine up as compression.
So I agree about the kick in point...unles you have an analogue stage out there in front, it will make it very hard to kick in coming out of a nominal digital system.
-T
TomWaterman
« Reply #61 on: March 06, 2008, 03:46:15 PM »
Can we not add some gain to the first ECC81 stage to get the signal up into the sidechain?
-T
living sounds
« Reply #62 on: March 07, 2008, 07:20:20 AM »
I third this. If levels have to be this high it won't be much use as an insert in a digital system without plugging in a line amp in front of it...
Denyle Guitars
« Reply #63 on: March 07, 2008, 07:37:09 AM »
Maybe you could lower or lose R103.
MartyMart
« Reply #64 on: March 07, 2008, 07:39:44 AM »
Just getting parts together for this and have a question.
The output caps 10uf 600v Poly's , any other recommendations as I'm finding
them hard to get and VERY expensive , like £8 each !
Found nice ones at Farnell but they are axial and 7cm across, so perhaps too big ??
VTL5C4/2 can be had from smallbear for $6 each BTW
Any info on the size and "hole width" of the two smaller heat sinks ??
There's several dozen similar things on Farnell's site.
For the BIG one, I'm going to use a large 8x6cm heat sink and attach it to
the case bottom/back.
Marty.
"Success is the ability to go from one failure to another with no loss of enthusiasm"
bernbrue
« Reply #65 on: March 07, 2008, 08:27:49 AM »
Quote from: "MartyMart"
Marty.
Marty,
spacing of the 10uF 630V Poly is 55mm. For the heatsink there is an ordering number in the BOM, look for further details there, pls. I´m just about to go on holiday. See you in three weeks.
Bernd
bernbrue
« Reply #66 on: March 07, 2008, 08:31:44 AM »
Here you go :-)
regards
Bernd
MartyMart
« Reply #67 on: March 07, 2008, 08:39:14 AM »
Thanks Bernd, much appreciated :-)
Enjoy your break .
Marty.
UPDATE __ UPDATE __ UPDATE !!
Here's the Farnell code for the 50mm high version : 1219493
and the 38mm high version is : 1219491
Footprint and board mounting are exact on these.
There should be plenty of room for the 50mm high, and it will dissipate more heat.
Tubefreak
« Reply #68 on: March 07, 2008, 11:06:15 AM »
Quote from: "living sounds"
Good point. Any constructive solutions?
Maarten
mcfarlane_audio
« Reply #69 on: March 07, 2008, 05:04:40 PM »
well i like the lowering r103 idea that could work, but call me crazy but looking at the compression curves with the mods it looks like the blue led (parallel) it looks like a slightly steeper version of no mods, but the 100k across looks less steep, so......maybe if we just strap them both across we will get a similar slope with lower threshold, i think im going to try this when ever i get mine up, but if someone whos already got one wants to try i would be grateful, thanks
Quote from: "pucho812"
yeah some guy named OHM invented this law which dictates all the crap we do
OneRoomStudios
« Reply #70 on: March 09, 2008, 08:32:58 PM »
What if a 12AT7 or 12AX7 were used in place of V102? This would allow the gain-staging in the signal path to remain the same, but would allow for more gain in the side-chain. If the problem is only that there is too high a threshold, wouldn't a higher amplification factor in the opto driving circuit effectively lower the threshold?
Denyle Guitars
« Reply #71 on: March 10, 2008, 01:29:00 PM »
Sure, try a 12dw7 & 5751 there as well.
Anyone working on a sidechain HP? Would a capacitor in series with R110 work? How about one parallel to R112.
« Reply #72 on: March 10, 2008, 05:35:34 PM »
Just a few quickies,
would any body able to tell me if this project can drive my 1ma VU meters??
And was the EDCOR 10k/10k good on the input?
Best
Pete
[silent:arts]
« Reply #73 on: March 10, 2008, 05:56:08 PM »
Quote from: "OneRoomStudios"
this would be the right way to lower the threshold for sure.
but without changing some component values around the tube there won't be any difference.
a little input transformer test will follow within the next two days.
btw, this is an open project, feel free to do your own experiments :thumb:
« Reply #74 on: March 10, 2008, 06:18:49 PM »
thanks volker, well def try my OEP's too, the EDCORs are just incredible value for money, cant quite believe how cheap they are..I think i read Analag use's them all the time..
[silent:arts]
« Reply #75 on: March 11, 2008, 12:30:13 PM »
INPUT TRANSFORMERS
today I opened up my box of transformers, and took some of them out where I thought they could fit in this circuit.
from left to right:
Edcor XSM10K/10K, Edcor WSM10K/10K, Lundahl LL1540, Haufe RK310-2, Haufe RK255-1, Haufe RK240, API 2621, Neve T.1442 (= 31267)
this was not a listening test :green:
FREQUENCY RESPONSE:
PHASE SHIFT:
THD+N:
Measuring conditions:
no output transformer,
Output Potentiometer = 100%, Input Potentiometer set for unity gain without transformers.
Generator Level = 0dBu
Zout 15Ω, Zin 100K
no Zobel networks etc used, just the transformers
(all at 1:1, except Haufe RK240 which is 1:2)
« Last Edit: February 09, 2009, 04:15:13 AM by [silent:arts] »
« Reply #76 on: March 11, 2008, 02:45:03 PM »
Wow.  Interesting stuff and nice work.  When do we get to read about the subjective listening tests?   :wink:
ioaudio
« Reply #77 on: March 11, 2008, 04:04:09 PM »
wow, there you have it.
losses from big iron/thick laminations, high dc-resistances (did you wire the ll1540 in series?) and the hf-characteristics from the different winding schemes.
many thanks for this test!
which hardware/software did you use?
-max
[silent:arts]
« Reply #78 on: March 11, 2008, 04:29:16 PM »
Quote from: "MikoKensington"
from me ? never. too subjective :green:
Quote from: "ioaudio"
yes
as always: Neutrik A2 / AS04 (which is a pain. NTI - please, do an update for this software) :roll:
Purusha
« Reply #79 on: March 11, 2008, 04:38:15 PM »
How about some sound samples? But now it's too late I guess  :cool:
Regards as always, Purusha
Last post November 28, 2008, 04:25:43 AM
by [silent:arts]
Last post August 10, 2011, 10:10:47 PM
by JimiH
Last post December 10, 2009, 05:43:37 PM
by Junction
Last post August 13, 2018, 10:11:57 PM
by TDM
