MODDING THE SLOPES (& THRESHOLD)a short story:
after building the first prototype I had a one (self made) problem:
I thought it doesn't compress. passed audio and measured well, but it just didn't want to compress. mhm.
I put in a (red) LED, paralleled to the Vactrol LED (to watch if it will light - since I was able to measure Audio at that point). There was no light, but - compression.
I emailed analag, kubi and viitalahde (since Jakkoo has a running build), and did some experiments while waiting for answers.
today I did some more measuring for this post:
test conditions:
Input 100%, Threshold 100%, Output adjusted for 0 dB Gain without compression.
(= this is although the minimum threshold before compression)
again, sockets were used paralleled to the Vactrol LED:
(blue LED antiparallel in this test)
at first:
analags circuit is working as is. my self made problem was the input level.
I tested with my nominal level of +6 dBu, and with the Input and Threshold full open: no compression. (rowan and jakkoo seams to like / have HIGH levels).
result:
with LEDs or Resistors paralleled to the Vactrol LED, you can mod the D-AOC for different slopes, and lower Threshold. use sockets to test what you like best, or if you want to be crazy: use a switch.
