Benny
D-AOC PCBs - the building and help Thread
« Reply #380 on: June 12, 2008, 04:16:55 AM »
Quote from: "bernbrue"
Benny,
did you use the relais boards as well? Which XLR connectors did you use?Check the polarity for relais power. Check also the transformer wiring (pin 1 is +, pin 4 is -) Can´t imagine that you´ve got wrong parts in there.
regards
Bernd
Hi Bernd,
I'm not using the relay boards at the moment. I'm using standard Neutrik XLR connectors. I'm gonna check the transformer connections again.
Jonkan
« Reply #381 on: June 12, 2008, 06:09:28 AM »
Klaus from musikding had some 24v omron relays coming in soon, cool!
Now i just need to figure out if i need 12v relays for my future poor mans 660 or 24v there too.
/J
bernbrue
« Reply #382 on: June 12, 2008, 06:47:22 AM »
keep your 12V relais for the PM670, you´ll need them :wink:
regards
Bernd
Jonkan
« Reply #383 on: June 14, 2008, 10:45:54 AM »
Will do!
Im trying to decide what edcor to use on the input. The XSM 10k:10k frequency plot looks strange to me so now its probably down to either xs1100 or the WSM 10k:10k for me.
If i understood correctly analag recommended the XSM line for the PM660, but was that just for that compressor, or in general?
Any suggestions on what to consider here, or is it basically either one is fine?
/J
seavote
« Reply #384 on: June 14, 2008, 12:53:23 PM »
i was just sourcing parts and have a few questions. i see that there are single turn trimmer pots and multi. what does that mean? one stepped (multi),one continuous(single)? which do i want for this project? i see there are holes for 4 posts on the board. most trimmers ive seen(not many) have 3 pins. is this for different pin out options or am i looking for a 4 pin trimmer?
what should i be looking for(specs) when ordering the blue and/or red  LEDs there are many options that i have no understanding of.What should i be looking for?
thanks for any help
Everyday is a gift. Thats why it's called the present
lofi
« Reply #385 on: June 14, 2008, 01:01:20 PM »
single turn covers the range in 360 deg, multi in many turns.
think the wholes cover the various types available?
just rough guesses while passing through
Iain
Are you professionally stupid, or just a gifted amateur.
Iain Westland (UK)
kazper
« Reply #386 on: June 14, 2008, 01:05:10 PM »
Just to add a little more to Lofi's description.
Single turn will get you there sometimes with a little fuss, Multiturn will get you exactly there.
I used multiturns myself..
Intentionally left blank
Jonkan
« Reply #387 on: June 16, 2008, 08:09:17 AM »
Sorry if im asking too many questions.. Will i need to use shielded cable for the connections inside the box? Or will just twisting the wires to the trick?
If its better to use shielded cable for all the connections, can i use the shield on the cable for the ground connection on the pots since i dont have any shielded cable with three conductors+shield at hand, only 2 conductors+shield...?
/J
[silent:arts]
« Reply #388 on: June 16, 2008, 09:00:01 AM »
Quote from: "Jonkan"
yes and yes
ChuckD
« Reply #389 on: June 18, 2008, 05:03:05 AM »
Still want to tweak the compression amount but this unit sounds great!
Here's my version...
Thanks Analag ,  Volker  and Darius ! :wink:
-ChuckD
[silent:arts]
« Reply #390 on: June 18, 2008, 05:12:35 AM »
:shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:
Chuck, what a beauty. speechless.
your DIY throughput is killing me :twisted:
and all your individual front panels are f###ing GREAT.
radiance
« Reply #391 on: June 18, 2008, 05:30:36 AM »
Yessire!!
THAT's an awesome looking piece of kit you've got there mate  :thumb:
"Knowing that you are dreaming, however, does not automatically guarantee full rationality.
Then again, being awake doesn't ensure good thinking, either." -  Lynne Levitan
bernbrue
« Reply #392 on: June 18, 2008, 06:14:50 AM »
Charles,
I´m searching for the right words, but your gear makes me speechless. I´m  really impressed by your incredible motivation to build all these excellent units. At the moment there are a lot of interesting projects. Having such a great input and seeing this amazing output makes me really happy.
regards
Bernd
Benny
« Reply #393 on: June 18, 2008, 06:19:48 AM »
Wow. I'm impressed. Another piece of art.  :thumb:
flintan
« Reply #394 on: June 18, 2008, 07:27:12 AM »
What a beauty!!
Jonkan
« Reply #395 on: June 19, 2008, 06:49:18 AM »
yeah!!! WOW!!!
Looks incredible!!!
I have no idea how to make something even remotely as good looking as your unit, or any of the other units you other guys have built for that matter. Very impressed!
Im still trying to find some nice scales for my fpd file. Anyone that has any good hpgl scale files for 25mm knobs?
/J
lofi
« Reply #396 on: June 22, 2008, 07:29:37 PM »
been all over the web looking for meters like that, with no luck
Sir, that is one of the most beautiful panels i have seen!!!
i am in Awe
Iain
Iain Westland (UK)
« Reply #397 on: June 23, 2008, 12:26:03 PM »
Can some one link me to Edcor or Hayboyer power transformers for this project in US
Please include required quantity, model #'s , prices, specs , looking to power a stereo PCB.
Interested in a torroid type.
Here is what I gathered so far
Edcor  XPWR055 ( specs not confirmed )  $45
Primaries  115v x 2
Secondaries  220v/0.1A , 9v/2.5A, 24V 0.5A
Hayboyer ?
curiousaudioparts at  gmail  dot  com
https://sites.google.com/site/diypartsstore/
jrfred453
« Reply #398 on: June 23, 2008, 05:33:56 PM »
I just received my Edcor power transformer a few days ago. I just called them up gave them the model number you listed above. It took about a week to wind it. The secondary windings were the voltages you listed.
mikeyB
« Reply #399 on: June 27, 2008, 11:44:00 AM »
I thought I read (Volker - possibly?) said the cap values for the relay psu were to big - holding the channels in circuit for too long 3 to 4 secs, with power removed. Did these get changed to make the bypass drop out quicker :?:
I asked about running valves on 12V heaters - would this have any bearings on the gain of the circuit?
making better music!
Last post November 28, 2008, 04:25:43 AM
by [silent:arts]
Last post August 10, 2011, 10:10:47 PM
by JimiH
Last post December 10, 2009, 05:43:37 PM
by Junction
Last post August 13, 2018, 10:11:57 PM
by TDM
