syn
Re: D-AOC PCBs - the building and help Thread
« Reply #720 on: February 15, 2010, 08:23:54 AM »
Hi
      I'll be building DAOC  and  was thinking of  switchable vactrols, (Also I'll go for a full wave rect. as in Kubi advanced version rather than having leds in parallel & anti parallel). Idea is to have VTL5C4/2  and VTL5C3/2  which is much faster, switchable from the front panel. Now I'm not sure is it ok to keep resistor side in parallel of all  vactrols (4vactrols in total in parallel) at all times hard wired, and to switch only the led part(s), or shall i switch between vactrol "sets", both, the resistor and the led part. Hope this sounds clear.
Thank you
« Last Edit: February 15, 2010, 08:26:18 AM by syn »
[silent:arts]
« Reply #721 on: February 15, 2010, 08:28:51 AM »
interesting question :)
there is the 3rd option of only switching the resistor side ...
however, I think switching only one side will affect the threshold point.
could be good, could be bad, depending on your needs  :o
syn
« Reply #722 on: February 15, 2010, 09:15:52 AM »
I remeber from the Kubi's thread (now missing) that having two optocuplers in anti parallel with one being switched off (basic DAOC opto. config, resistor side) is no problem, but i'm not sure what is going to happen when having 4 in parallel at all times with one "set" switched off.
I dont mind if  I have to readjust the threshold when switching from one type of
vactrols to another.
[silent:arts]
« Reply #723 on: February 15, 2010, 09:27:43 AM »
just looked at the datasheet you posted.
the VTL5C3/2 is much faster, but the other values are very different too :-\
syn
« Reply #724 on: February 15, 2010, 09:56:04 AM »
yes, but mine main concern is OFF RESISTANCE. For everything else VTL5C3/2 just have same/similar/ "more range" values. I might be wrong tho. It was used
as opto element in L2 builds, so I hope i'm not missing it all together ;D
« Last Edit: February 15, 2010, 10:00:01 AM by syn »
syn
« Reply #725 on: February 15, 2010, 10:16:11 AM »
and,  hey, you did excellent job on the PCB, both electro. and  visual. quietest tube piece that I've made.thank you very much.
[silent:arts]
« Reply #726 on: February 15, 2010, 11:10:50 AM »
thank you Sir. don't forget to post pics :) :) :)
pucho812
« Reply #727 on: March 16, 2010, 12:25:48 AM »
Need to post my  NYD edition daoc. I posted the front panel which didn't make the grade on page one :(  It may be ugly but she is all mine. I have it up and running. Much to my surprise It started working the first time I ran audio which is rare when I DIY. This was before I adjusted the heaters to the 6.3 spec.  However before the adjustment it did some dodgy things it no longer is doing. I still need to wire up the link switch and do the bypass on each channel. but man this thing sounds really good.
I would like to thank the academy, my manager,.....
No seriously I wanna thank analag  and silent arts for the project.  and a shout to miko for his hand in me having  this project
once I have those switches in I will post the insides.
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
[silent:arts]
« Reply #728 on: March 16, 2010, 04:21:24 AM »
fixed ;D ;D ;D
with some more fotos incl. the insight you will get your own banner :D
Matthew Jacobs
« Reply #729 on: March 16, 2010, 07:28:55 PM »
I've decided to go with Sowter 4383 transformers on the input and outputs. First time I'm gonna use Sowter.... We'll how it goes....
J
My Sowters arrived yesterday. I am all set and ready to get this baby up a running before the weekend.
I am using the 4383 (mic/line - input/output - 600/10K)
http://www.sowter.co.uk/specs/4383.htm
Can anyone tell me what the black lead does? And how should I hook it up? To earth?
Thanks for your time.
J
pucho812
« Reply #730 on: March 16, 2010, 11:24:39 PM »
fixed ;D ;D ;D
with some more photos incl. the insight you will get your own banner :D
I got some photos I will upload them when I get home. My own banner awesome.  If I am ever in Germany Will have to get you a beer or 4 and a signed photo of David Hasselhoff.
mathew I would skip the black should work just fine.  but black would connect to ground or that's how it looks on any jensen transformer schematic.
edit: attached is a photo. I did not put in the bypass boards as they went into another project but I did do a hardwired bypass.
« Last Edit: March 17, 2010, 01:13:26 AM by pucho812 »
[silent:arts]
« Reply #731 on: March 17, 2010, 04:37:28 AM »
... If I am ever in Germany Will have to get you a beer or 4 and a signed photo of David Hasselhoff.
we can skip David but the beer is fine :D
pucho812
« Reply #732 on: March 17, 2010, 06:58:59 AM »
you sure? I hear he is quite big over there? well cool I have a banner :)
Brizco
« Reply #733 on: March 21, 2010, 05:59:38 AM »
This is mine  ;D
thanks to analag, volker and frank!
[silent:arts]
« Reply #734 on: March 21, 2010, 06:10:19 AM »
WOW, what a beauty !!!
please some more pics ;D
one flat from the front to put it in the rack at page 1,
some more shots for doing your banner ;D ;D ;D ;D
(and shorten that long PSU Xformer screw, it is dangerous if it touches the top of the case ...)
« Last Edit: March 21, 2010, 06:14:34 AM by [silent:arts] »
Brizco
« Reply #735 on: March 21, 2010, 06:23:57 AM »
thanks :) the screw doesn't touch the top, that just looks like.
im a poor fotographer...
« Last Edit: March 21, 2010, 06:26:57 AM by Brizco »
[silent:arts]
« Reply #736 on: March 21, 2010, 07:18:20 AM »
... and added to the huge D-AOC Rack :D
Jonkan
« Reply #737 on: March 21, 2010, 07:35:42 AM »
mmm, tasty.
I really should finish mine.
Brizco
« Reply #738 on: March 25, 2010, 09:27:22 AM »
After a few days using the d-aoc in the "studio" i really want to say it once again: THANKS!
fallout
« Reply #739 on: March 25, 2010, 09:35:02 AM »
Another cool looking project I missed out on.. Are there any plans to do another run of PCBs for this?
-jay
Last post November 28, 2008, 04:25:43 AM
by [silent:arts]
Last post August 10, 2011, 10:10:47 PM
by JimiH
Last post December 10, 2009, 05:43:37 PM
by Junction
Last post August 13, 2018, 10:11:57 PM
by TDM
