Hi, Sorry if this seems obvious, but I've been doing quite a bit of reading about ground loops. One article recommended on this forum was this one:
http://www.rane.com/note110.html
If you look at the first diagram under the title "The Absolute Best Right Way To Do It" it shows two devices connected by a balanced cable.
Now my question is what if both of these devices are mains powered, this means that they both will be plugged into the mains, the grounds of the mains sockets are connected in the wall , then it follows that we will have created a loop through the ground cable in the wall, through the first device, then the interconnecting balanced cable which is grounded to both devices and back into the wall socket??? Won't this cause a ground loop???
Yours groundloopedly
Albert
Albert
