I'm in the process of tracing out a 1930's Teladi bottle mic. I'll take some photos tomorrow, but for now here's most of the circuit.
A couple of features here which are worth noting:
The PSU is standard thing , heaters are 6.3V AC twisted pairs.
It has a little 150V voltage regulator tube inside the mic. I've never seen this before in a mic. The manufacturer is "Stabiliovolt"
Tubes are 2 x ECB3.
Although it has an output transformer, it runs unbalanced.
There are grotty electro output caps in the PSU. This seems unnecessary to me unless it is to protect the output xformer from accidental connection to DC? Maybe it is to stop the switch grounding the input of whatever comes next?
There is a long wax-filled tube that runs the entire length of the body, which has 7 wires coming out of it. From the circuit I believe this is 4 capacitors (two with a common ground - yellow box marked 3 4 5). I'll desolder and get some measurements to confirm this.
I do wonder why they are in a tube. There were a lot of small mic companies in Germany at the time so maybe it is some kind of attempt to keep the values secret?
[Finally, the 1uF cap between the 40K and 50K resistors looks odd to me. Is it some kind of filter for the power supply? I often see stabilisation caps to ground, but this seems strange.] EDIT: THIS IS WRONG! NOTE ADDED BELOW
Let me know your thoughts!
Tubes are 2 x ECB3.
