ioaudio
finally : the better lorlins
« on: April 04, 2008, 03:24:29 PM »
i just bought one, and yes -feels better, looks better but is identical to lorlins.
http://www.banzaieffects.com/Rotary-Switch-1x12-Gold-pr-25743.html
 :thumb:
[silent:arts]
« Reply #1 on: April 04, 2008, 03:36:29 PM »
end-stop programable ?
shorting or non-shorting ?
I'm interested in the better feeling - is it harder, softer ?
should order some and try it out.
ioaudio
« Reply #2 on: April 04, 2008, 04:23:16 PM »
Quote from: "[silent:arts
"]end-stop programable ?
yes. similar to lorlins, but the ring fit´s a bit tighter so it doesnt fall out while handling without the nut tightened.
"]shorting or non-shorting ?
i had to try out, because they didnt specify - but they appear non-shorting, break-before-make.
"]I'm interested in the better feeling - is it harder, softer ?
more precise. did i mention these are gold plated?
not bad for a nylon switch.
inputoutput
« Reply #3 on: April 04, 2008, 04:58:24 PM »
The 2x6 Lorlins are pyton.  If you 'accidentally' use too much force on them, they easily turn into 1x12
flintan
« Reply #4 on: April 04, 2008, 06:10:32 PM »
Quote from: "ioaudio"
Thats also a good thing! Can sometimes be a real ***** to fit them in tight spots without nuts..
Sorry for a bit OT but, have you ever had the switch got stuck after tightening the inner nut maybe a little too hard? And still being after loosening it..
Last post June 06, 2004, 05:38:47 AM
by TheRealWaldo
Last post January 03, 2005, 02:40:07 PM
by jrmintz
Last post September 23, 2005, 05:11:47 PM
by Mbira
Last post July 10, 2006, 11:10:53 AM
by emtee
