Re: the 1954 Limiter!!
« Reply #80 on: February 21, 2019, 12:46:26 AM »
+1
Who's we? ;D
Thanks guys... turned out the sound was from the preamp (it is very quiet sorta had to jack the volume to hear it). Thought the input tube was on it's way out but when I looked under it was this solder point that's been plaguing me for the past year. For some reason the coax cable I used for the grid caps doesn't wanna accept solder. But I scraped it up a bit this time, hit it with some solder that has more flux and lead and it's more solid than the other times so hopefully it stays.
We consists of my bassist and I lol.
scott2000
« Reply #81 on: February 21, 2019, 06:31:33 AM »
You're not the Dave from M>D> are you???
« Reply #82 on: February 21, 2019, 07:06:07 AM »
Umm I mean my band is called Moa Desert. I'm not sure if that's what you mean. We have like 20 fans or something and haven't released anything since 2015 and are going to call it quits after this upcoming album.
scott2000
« Reply #83 on: February 21, 2019, 07:10:00 AM »
I thought so....
You guy's are crazy good!
That Seal cover is insane
« Last Edit: February 21, 2019, 07:13:41 AM by scott2000 »
« Reply #84 on: February 23, 2019, 08:34:44 PM »
I thought so....
thanks man... that drummer isn't the same one still in our band
hope you like our new stuff cause it's the last we're doing... gonna sell all the equipment we have after this too lol.
recorded a bit with this limiter to a track and it really couldn't fit better.. i'll post a clip next week.
opacheco
« Reply #85 on: February 24, 2019, 07:00:26 PM »
......A Fairchild for example has an output resistance of 100 ohms before its diodes, which enables its speed to get down to uS........
Dave, How I can get this figure from the Fairchild Schematics??
I would try losing the 10k's and putting in two cathode followers from another tube to drive the 6AL5, this would take the source resistance down to around 250 ohms.
I thought the same, two catodes followers and a I Solid State Diodes Bridge instance the 6LA5 will give us a very low charging times value like the Fairchild configuration!!
Opacheco.
I love the Vaccum Tubes Sound!!!
« Reply #86 on: May 19, 2020, 10:03:43 PM »
It's looking sorta uncertain that we're ever finishing this album so i'll just post a sample of when this compressor sounds like on a vocal chain, cause I always intended to once we finished...
https://drive.google.com/file/d/1y4UiBnp1ag0ePHMRVm6zvwlXkT65ayF8/view?usp=sharing
There's no EQ... just MK47 to this compressor onto some tape.
« Last Edit: May 19, 2020, 10:08:25 PM by davemascera »
scott2000
« Reply #87 on: May 22, 2020, 04:56:41 PM »
Yeah Dave!
Sounds real nice... keeping it right in there....  Your voice has always been pretty great...
Can't wait to hear the mix...
opacheco
« Reply #88 on: May 23, 2020, 09:19:03 PM »
Dave, it is really awesome!!....did you used the original 1964 schematic for?
opacheco
« Reply #89 on: May 28, 2020, 10:40:03 AM »
opacheco
I used the one I posted. The biggest difference was that I changed the release/attack pots as suggested
Last post December 22, 2004, 07:02:40 PM
by PRR
Last post April 05, 2005, 02:17:05 AM
by PRR
Last post September 12, 2005, 03:32:11 PM
by Bryson
Last post August 10, 2012, 04:28:43 PM
by EmRR
