Bec
Headphone distribution box
« on: October 09, 2004, 10:05:02 PM »
Has anyone got a project for a headphone distribution box?
I need at least 4 outputs.
I did a google search and kept finding dead ends.
Please help me.
Bec
just having a go!
CJ
« Reply #1 on: October 09, 2004, 10:18:58 PM »
do a search on Headwize.
cj
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
Kev
« Reply #2 on: October 10, 2004, 03:44:27 AM »
Bec ???
my site ... you should know that.
BUT first you need to work out how and what you will drive this distribution box with.
If you only have a standard Headphone out from say ... an M-Box then you probably can't get much more than two H/P's out of it with something like a standard Y cord.
If you have a small HiFi amp at about 25 to 50 watts then a 4 to 8 way distribution box or two 4 way units will be fine ...
Basically all H/Ps are driven in parallel with some resistors in series with each line (left and right).  15 to 30 ohms say.  I may have used 18  ?
If this will mean you have to buy or make an amp and spend money then an alternative option might be one of the budget Headphone amps from A or B.
They are quite good value and do give some cool options.
These will give enough volume except when working with loud drum kits and screaming guitar solos at MAX level.
Kev
DIY Factory
PRR
« Reply #3 on: October 10, 2004, 03:46:16 AM »
How "hot" does it have to be? Normal, or live music around drummers?
Does everybody get the same level? (If not, what you really want is a lot of individual headphone amps.)
The general plan is to use a loudspeaker amp plus series resistors. An 8 Watt 8Ω ohm speaker amp (cheap hi-fi) with a separate 27Ω series resistor for each ear will work fine up to 7 32Ω headphones (or up to 3 dead shorts).
Kev
« Reply #4 on: October 10, 2004, 03:52:23 AM »
Looks like we are in at the same time !!   :green:
you get that
As PRR said ... there are mix issues to consider  ... same mix ... same EQ ...  same level ... etc etc
how complicated do you want to get in the future and try to make things that can grow with your needs.
Kev
DIY Factory
Bec
« Reply #5 on: October 10, 2004, 07:58:03 AM »
Thanks Guys
Sorry Kev!!!!! I should know a lot of things.
I need to think about that now.
Bec
just having a go!
12afael
« Reply #6 on: October 10, 2004, 11:43:57 AM »
paia have a project and I see a couple of schematics on rane page.
heavy metal is the law!!!
josan
« Reply #7 on: October 10, 2004, 03:39:57 PM »
the paia project is a good one for doing a straight forward opamp project
I took the schematic and put it on a a 2 by 3 " card and found an old
headphone distribution box at a flea market  for 5 bucks .  It was a great diy
as I did the board from scratch. Used free software to design the pcb
etc .  The actual project uses 5532 op amps so it's cheap and sounds great
plenty of power if you use a 15 volt power supply instead of the 12 you could probably go higher  but you some caps might have to be changed.  Great way to set up an infastructure for DIY and get a good usable end product.
« Reply #8 on: October 10, 2004, 11:03:05 PM »
I built the Paia kit and have used it for years with no problems. It's decent sounding and reasonably robust, although I wouldn't call it rugged.
 :thumb:
Seth
The definition of insanity: "Hey, this thing could be really cool - if I had the money to fix it up, which I don't, but if I did it could be really cool - if I had the time, which I don't, but
Last post January 16, 2009, 04:50:22 PM
by aronaut
Last post February 10, 2009, 06:51:49 AM
by jdbakker
Last post May 12, 2009, 04:17:47 PM
by Biasrocks
Last post August 17, 2009, 02:36:39 PM
by guitarguy12387
