The 513 would be the closest size, but still not tall enough.
My complaint with these boxes is that the end panels are flimsy. The box is made from 2 u-shaped pieces of steel. The end panels do not have any support at the top, so you have to add something behind them to prevent bending when you connect a mic, XLR, or power. Adding a L bracket adds a screw in the top plate, which is unappealing to me. I have epoxied a metal bar in there which works OK, but unless it is tapped and screwed to the end plates, they bend OUT when disconnecting.
Mike
