Perforated plywood?
Kit
Sweden
Anyone of you got any experience with using perforated plywood as acoustic treatment of a room?
Thanks.
If the holes are the same size then you will only get absorption in a very narrow region of frequencies, the Helmholtz Resonator effect. You would need a lot of different, specific size holes to tune the panel.
http://www.audioholics.com/education/acoustics-principles/helmholtz-resonant-absorber
I wonder if using a variable distance between the backing surface would broaden the bandwidth? Some damping would certainly widen the Q.
I think slats are the way to go. There's loads of info on john sayers forums and users there are pretty keen in helping
http://www.johnlsayers.com/phpBB2/index.php
