SSLtech
So I received that LA-2a case which I bought on eBay some weeks ago (it was shipped to my mother, who then re-shipped it to the USA since the first seller wouldn't ship internationally).
I was looking at making an affordable hinge-fronted version, but I see some issues:
Everyone will almost certainly use the same pots, switches, octal sockets, tube sockets, turret boards etc. (or at least, hole-compatible versions) -but the meter and the transformers are difficult.
Not everyone wants to use UTC transformers, and not everyone wants to use those... -not everyone can find or AFFORD them! In the BLOO version this was addressed by making separate 'adaptor plates' for each transformer type. -This is technically possible again, but I wonder if people will want to go to the extra expense...
In addition, the front panel METER is another problem. The original meter was a Beede, but they no longer supply in quantities under a thousand (at over $100 each, that's a $100,000 investment which I know we can't make!) -The best meter that you can easily get is a Sifam, but the Sifam which fits the Beede-sized hole is too deep for the inside of the LA-2a body, and collides with the turret board when you shut the front panel. There is a HOYT option, but their meters simply do not read accurately... -Sure, they fit the hole and look alright, but I don't like them
-If I make it with a hole for a meter which won't fit most meters available, (API meters fall right through the Beede hole, for example) then that's no use to most builders.
-If I made them with "Cut your own meter and transformer holes, I'd expect most people not to be happy with the idea.... but I'm tossing the notion out there, just in case people think it's acceptable.
Basically, here's the deal: -If enough people are interested and can agree on a COMMON set of transformer and meter holes, there might be enough interest to do the run. -I'm asking to see if people can agree on what they'd want.
Keith
Keith
