DIY passive attenuator
phantom power
Visalia, CA
After searching the forum, I found a lot of full-featured monitor controller discussions, but nothing about a simple one-knob passive attenuator.
Something like this shouldn't be too hard right?
If someone could point me to some info on something like this, I'd really appreciate it.
-AE
Not much to do. A usually terribly expensive rotary and a bunch of resistors. Done.
I did one with a cheap switch and some signal relays to switch in combinations of 1dB, 2dB, 4dB and 8dB pads (giving 0dB to 15dB attenuation).
Various nice & low BOM-cost circuits around here, do a search.
NYD posted a fine & coarse 600 Ohm passive attenuator & maybe the circuit from I forgot his username (Mr Hinson his real name IIRIC) is still up.
[quote author="cannikin"]
http://idisk.mac.com/cannikin-Public/vumeter/inside.jpg[/quote]
Whoa, you had to add a power supply for the monitoring-stuff of a passive attenuator ? :cool: :shock: :thumb:
[quote author="king-rb"]i got a few four deck elma switches so im building follow attenuator for my new monitor controller... http://www.goldpt.com/schm_ser.html
what are the resistor values if i want 1.0db steps =?[/quote]
This one is not balanced and not constant impedance. It's just a simple resistor divider.
Here's a calculator to find out the steps and resitors:
http://homepages.tcp.co.uk/~nroberts/atten.html
I have made a passive attenuator for monitoring using elma 24pos. switch, simple but a lot of work...
You'll find a lot of info with google.
[quote author="clintrubber"] Whoa, you had to add a power supply for the monitoring-stuff of a passive attenuator ? :cool: :shock: :thumb:[/quote]
No that was for the JLM vu meter buffers
[quote author="cannikin"][quote author="clintrubber"] Whoa, you had to add a power supply for the monitoring-stuff of a passive attenuator ? :cool: :shock: :thumb:[/quote]
No that was for the JLM vu meter buffers[/quote]
Yep, we both meant the same, ehh, monitoring by eye, not the monitoring by ear. The audio-path between in & out is all passive, right ? :cool:
[quote author="cannikin"]Yes completely passive :grin: :grin:[/quote]
Note I didn't even mention the effective use of rackspace :wink:
I like it :thumb:
