LH0002CH -- what is inside?
« on: April 22, 2008, 09:46:12 PM »
Here is a datasheet:
http://www.datasheetcatalog.org/datasheet/calogic/LH0002.PDF
It says "0.1% THD on 1 KHz 5V rms". Had anybody used them for audio? Unfortunately I can't find schematic to see how prone they are to crossover distortions...
bcarso
« Reply #1 on: April 22, 2008, 09:51:38 PM »
They were originally a National Semi part.  IIRC they are hybrids with cascaded complementary emitter followers.  Slightly less than unity voltage gain, and were touted as buffers to incorporate inside the feedback loop with an opamp driving.  Opamps of the day were slow enough that the LH part added negligible phase shift.
EDIT:
In fact:
http://www.datasheetcatalog.org/datasheet/nationalsemiconductor/DS005560.PDF
Freq Band
« Reply #2 on: April 22, 2008, 10:33:03 PM »
Audio by Van Alstine had a kit for a headphone amp which used the LH0002 as a buffer/output booster.
Here it is described, and schematics (parts layout, pc board).
(scroll mid-way down)
http://www.avahifi.com/root/audio_basics/ab_pdf/ab1994-04-05-06.pdf
I built it using point-to-point, but used the LH0002 can  instead of the DIP.
Sounds fine. I have not yet A/B it with my more recent HP amps.....to see if I can hear any differences, or done any measurements.
They're obslte, but show up on ebay at a good price once in a while I bought 20 of them for about...??.....$20 ??
App note 227
http://my.ece.ucsb.edu/bobsclass/2C/tutorials/App%20notes/an-227.pdf
=FB=
Facebook is an unfortunate way to receive news, and a good place to receive rumors.
« Reply #3 on: April 23, 2008, 12:34:50 AM »
Thanks a lot for the info!
« Reply #4 on: April 23, 2008, 03:01:05 PM »
I have 20 of them, let's use for a headphone distribution amp...
guy_4
« Reply #5 on: April 24, 2008, 08:02:14 PM »
It is used as a video output driver on the SSL E/G computer...probably good enough for a headphones amp  :grin:
Guy
"If you think it is expensive to hire a professional, wait until you hire an amateur ! "   Red ADAIR
Dan Kennedy
« Reply #6 on: April 24, 2008, 11:59:42 PM »
I use a variation of the circuit in a high pass circuit in my EQ, simple to build with a pair of 4403's and 4401's and a couple of SIP resistor networks.
Use 47 ohm and 6K8 to start.
« Reply #7 on: April 25, 2008, 12:01:50 AM »
Quote from: "Dan Kennedy"
Thanks, it is exactly what I was thinking about today, to use them in crossovers.  :cool:
Last post January 11, 2005, 04:17:11 PM
by Gus
Last post July 02, 2005, 07:59:53 AM
by tony dB
Last post July 30, 2005, 02:23:32 AM
by MHanson
Last post March 17, 2006, 02:59:35 AM
by gyraf
