LH0002CH -- what is inside?
G
Guest
Guest
Here is a datasheet:
http://www.datasheetcatalog.org/datasheet/calogic/LH0002.PDF
It says "0.1% THD on 1 KHz 5V rms". Had anybody used them for audio? Unfortunately I can't find schematic to see how prone they are to crossover distortions...
They were originally a National Semi part. IIRC they are hybrids with cascaded complementary emitter followers. Slightly less than unity voltage gain, and were touted as buffers to incorporate inside the feedback loop with an opamp driving. Opamps of the day were slow enough that the LH part added negligible phase shift.
EDIT:
In fact:
http://www.datasheetcatalog.org/datasheet/nationalsemiconductor/DS005560.PDF
Audio by Van Alstine had a kit for a headphone amp which used the LH0002 as a buffer/output booster.
Here it is described, and schematics (parts layout, pc board).
(scroll mid-way down)
http://www.avahifi.com/root/audio_basics/ab_pdf/ab1994-04-05-06.pdf
I built it using point-to-point, but used the LH0002 can instead of the DIP.
Sounds fine. I have not yet A/B it with my more recent HP amps.....to see if I can hear any differences, or done any measurements.
They're obslte, but show up on ebay at a good price once in a while I bought 20 of them for about...??.....$20 ??
App note 227
http://my.ece.ucsb.edu/bobsclass/2C/tutorials/App%20notes/an-227.pdf
=FB=
[quote author="Dan Kennedy"]I use a variation of the circuit in a high pass circuit in my EQ, simple to build with a pair of 4403's and 4401's and a couple of SIP resistor networks.
Use 47 ohm and 6K8 to start.[/quote]
Thanks, it is exactly what I was thinking about today, to use them in crossovers. :cool:
