PRR
How transistors work
« on: April 23, 2008, 12:35:43 AM »
Tubes, I understand. Transistors are different, mysterious, and the arcane theory which grew up around them is no use at all. I have a mental model which gets me to an answer but I can't put it in words.
This guy has got it right:
http://www.satcure-focus.com/tutor/page4.htm
It even models breakdown voltage.
Re: How transistors work
« Reply #1 on: April 23, 2008, 01:03:26 AM »
Quote from: "PRR"
Nice! :D
No stupid holes, electrons, potential barriers! :)
I have one more theory: with human body, legs, arms...
Ptownkid
« Reply #2 on: April 23, 2008, 10:40:29 AM »
wow, very clear cut!
gar381
« Reply #3 on: April 23, 2008, 11:36:58 AM »
Nice!! :thumb:
GARY
RETIRED.....  from 51yrs in Show Biz
gar2520, gar1731,garAM10,gar918 DOAs at  http://capi-gear.com/catalog/index.php?cPath=71_72
NEW Sphere section  http://gar381interests.com/gar381interests.html
amorris
« Reply #4 on: April 23, 2008, 01:27:26 PM »
wow, that is nice. can we erase all the other explainations everywhere on the internet and textbooks now????
sonicmook56
« Reply #5 on: April 23, 2008, 06:32:55 PM »
Quote from: "Wavebourn"
Let's hear it!
I always hated the holes/atom thing.
This is very clear!
~B
mikep
« Reply #6 on: April 23, 2008, 06:52:21 PM »
Fascinating, but this goes against everything I know to be true.  I am almost certain that transistors are filled with highly compressed smoke, not water, electron holes, doughnut holes, or what have you.  Capacitors are also filled with smoke, but it has very different properties, and hence a different smell.
Mike P
legris
« Reply #7 on: April 23, 2008, 06:53:47 PM »
Very interesting  :grin: . New here and so much to learn!
« Reply #8 on: April 23, 2008, 07:38:44 PM »
Quote from: "sonicmook56"
Let's hear it!
What PRR posted is more consistent than my kinesthetic version.  :grin:
PRR
« Reply #9 on: April 24, 2008, 01:57:23 AM »
What's the difference? Oh, when it gets out it is the difference between stink and soaked. But functionally, you can have smoke so compressed that it wants to fall down, and compressed smoke forcing-up the valve.
If you replace the one valve with a zillion elastic force-fields between crystal atoms, it is not so very far off from what the electron/hole-theorists claim to be true. Maybe the only fault in their logic is their irrational faith in impossible objects like electrons. Or maybe "electrons" is really just another word for very-very highly compressed smoke. Smoke so compact that it can skim through a metallic lattice, but not through an amorphous ceramic.
Larrchild
« Reply #10 on: April 26, 2008, 06:18:03 PM »
Somewhere on a Hydraulics forum, someone is using a transistor to explain things.
CJ
« Reply #11 on: April 28, 2008, 02:02:56 AM »
stephan hawking just outlawed transformers.
If I can't fix it, I can fix it so nobody else can!
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
Andy Peters
« Reply #12 on: April 28, 2008, 02:07:46 AM »
Quote from: "CJ"
He must've seen the movie.
Clearly, Hawking hasn't figured out his grand theory of everything because nothing explains Michael Bay.
-a
"On the Internet, nobody can hear you mix a band"
bcarso
« Reply #13 on: April 28, 2008, 03:19:58 AM »
Quote from: "Andy Peters"
Quote from: "CJ"
-a
Or for that matter, the popularity of American Idol, and in particular why I'm actually watching it this season :shock:  :oops:
jeffrey_burr
« Reply #14 on: May 06, 2008, 01:42:11 AM »
Thank you PRR for posting this link.  I can't say I "understand" tubes really but at least I can set up a stage and bias it properly.  Transistors are different, mysterious, and my mental model was going absolutely nowhere.
Welcome to Costco.  I love you.
wtmnmf
« Reply #15 on: May 11, 2008, 01:14:05 PM »
It is a good image, however it would not work!
What is needed is an isolated balance tube from C to the underside of the plunger.  This way the plunger will not feel the pressure from C (it will now have a differential pressure of zero) and B will be able to move the plunger with little effort. Also, E will need to be low impedance, or else C will put back pressure on B. What is needed is an open tube draining into a reservoir below. That way C can drain freely and B can drain freely. In fact, in this model there would be no need for B to drain at all because it operates on pressure and not flow. You could add a paddle wheel with a rope or belt draped over the hub which pulled on a lever to actuate the plunger. It will be getting rather Goldberg-esque at this point, but it will work!  :green:
Last post May 10, 2006, 07:27:27 PM
by BladeSG
Last post June 02, 2005, 05:54:39 PM
by clintrubber
Last post January 27, 2006, 02:12:15 PM
by BBob
Last post January 27, 2006, 10:23:14 AM
by Samuel Groner
