5K linear pot with push-pull shaft switch?
emrr
NC, USA
Anyone know of one commonly stocked? I've found as close as 10K from at least one guitar/amp supplier. I'm contemplating adding a switch to a circuit without drilling another panel hole, and the switch is related to a particular 5K pot.
State Electronics will make you one, but their pots are expensive (either Claro or AB) - and they have a set up charge. If you were to order from them, I'd suggest looking into a group buy-type arrangement to offset costs.
You probably knew this, but anyway...
Justin
Thanks, I'll probably just drill another hole before going there. But I should check on price.
http://www.wagner.net.au/
If you want a few, I can order them through work and send them to you. They are around $6 Australian Dollars IIRC. But they really are a 6mm shaft, not 1/4"...
