5K linear pot with push-pull shaft switch?
« on: April 26, 2008, 01:08:11 AM »
Anyone know of one commonly stocked?  I've found as close as 10K from at least one guitar/amp supplier.  I'm contemplating adding a switch to a circuit without drilling another panel hole, and the switch is related to a particular 5K pot.
« Reply #1 on: April 26, 2008, 06:34:03 AM »
State Electronics will make you one, but their pots are expensive (either Claro or AB) - and they have a set up charge. If you were to order from them, I'd suggest looking into a group buy-type arrangement to offset costs.
You probably knew this, but anyway...
Justin
Prepare yourself. You are about to become the voice of Interplanetary Parliament.
« Reply #2 on: April 26, 2008, 10:37:21 AM »
Thanks, I'll probably just drill another hole before going there.  But I should check on price.
mnats
« Reply #3 on: May 09, 2008, 05:45:07 PM »
http://www.wagner.net.au/
If you want a few, I can order them through work and send them to you. They are around $6 Australian Dollars IIRC. But they really are a 6mm shaft, not 1/4"...
Last post July 20, 2004, 09:43:42 AM
by jhaible
Last post May 22, 2006, 02:07:20 AM
by adamasd
Last post June 10, 2007, 03:32:48 AM
by PRR
Last post September 05, 2019, 12:37:49 PM
by PRR
