dripelectronics
drip opto la2a and sowter power .... solved
« on: April 27, 2008, 01:07:27 AM »
writting a fix sheet now ,
and will post in a few hours .
have this unit here with the sowter power transformer
running with a lower noise floor than the re-issue/vintage unit
with
zero hum .
thanks dan for sending your unit .
and Uwe for your struggle and solutions .
gosh , i dont think ill discontinue the ver 2 after all .
g.
g.
[email protected]
(not so good with PM's so dont pm...use email)
la2a ver 3 atoms manual : http://lomayesva.com/la2a_pcb_ver3.pdf
v72 manual : http://lomayesva.com/v72_pcb_manual.pdf
tommypiper
« Reply #1 on: April 27, 2008, 02:25:25 PM »
Greg, how is the V72 output stage version coming?  That one seems so dang unique and interesting.  You were thinking of options for it... mic input?  Fascinating.
Thanks for all your projects, info, and making T4s.
Imagine a wet, slightly chilled from its gas release and decompression, with water droplets condensing, sucking surface tension, slowly sliding down the side, capped by a healthy virgin froth on top..
dripelectronics
« Reply #2 on: April 27, 2008, 11:45:15 PM »
hi there,  still designing the fix sheet , should have her up
on monday  or so , i know a few people were having problems.
just wanted to re-assure there is solutions.
the la2a/v72 hybrid AC version  is getting printed now.
i decided just to go ahead and do a solid v72 pre board .
honestly it was the gain switch delaying the whole thing .
and the OCD prevented me from moving forward..lol
but it dawned on me when i went to a recording studio ,
most v72's just used a pot on the input or out put section.
should have her done in a few weeks.
best .
g.
g.
[email protected]
tommypiper
« Reply #3 on: April 27, 2008, 11:59:00 PM »
Good, looking forward to the V72 version.
You said you decided to make a solid pre board?  What does that mean?  You mean mic pre?  Or a separate board for the LA2?
Last post April 10, 2007, 11:51:24 PM
by Stagefright13
Last post April 13, 2007, 08:43:58 PM
by Stagefright13
Last post April 24, 2012, 04:36:03 PM
by gemini86
Last post September 10, 2018, 07:26:19 PM
by clister01
