matthias
I'm building 2 Gyraf Pultecs in one enclusre with one set of knobs...
I had some problems with hum and hf noise in the last tests...
so I changed the location of the boards and put the big power transformer out of the box...and it's really better now...
but I'm still unsure how to connect the both pcbs with 2 transformers
actually I have a 2*12V 120VA toroid to drive both pcbs
and a 2*12V toroid 30VA to get the 220 V for the tubes
I still remember some interesting statements I read in the last days of the old board...
"you have to connect both windings of the trafo, otherwise you get hum"
"never connect more than one rectifier to one trafo"
what should I do??
first of all:
is a 50va "main transformer" enough to drive both pcbs ??
I have to replace the 120va because the second winding delivers only 10V , the other 17V so it is broken...
should I connect only one lead of the 2*main trafo to the first pcb and then grab the power for the 2nd after the rectifier of the 1st pcb ??
or should I use both "windings" of the trafo and each set of rectifiers on every board ?? (use the 2*trafos as I would do with 4 single trafos)
so any advice is really welcome
thank you
here are some preview pics I shot at my last test setting...
more pics if I have finished...
cheers,
matthias
what should I do??
first of all:
thank you
cheers,
matthias
