Hi ilikeit,
Why didn't you tell us the exact reference of your input module ?
It is labelled on the pcb as 1.169.xxx
Anyway, you are correct for the power supply pins
( OV is wired on 2 pins PP2-6 and PP2-7 )
The audio output of this input unit is unbalanced on pin PP1-12
If you don't want to go through the MUTE and SOLO FET's you can use PP1-1 as output.
Don't know if you need them, but AUX pre-fader send is on pin PP2-13, and post-fader on PP2-11 (you have to link PP1-11 and PP1-12 toghether )
If you want a balanced output you'll have to build an additionnal board (SSM2142 or equivalent is a good solution )
Hope this helps !
Guy
